I tried to connect to my Synology Diskstation with WebDAV, it works but the folder is empty. I need help to configure it.
Dear stefansauga
Thank you for using NetDrive3.
I reviewed the log file you attached.
In the log file, the url you set is http://sauga.synology.me:5000. It’s a DSM url not webdav.
The default url of Synology NAS is 5005 for http.
If you set the url to " http://sauga.synology.me:5005", you can connect to your NAS.
I misunderstood something: The rules for port forwarding were set incorrectly in my router. I have not reset to the regular ports during testing and so the error exists. Well, after adjusting to port 5005, it works and I’m grateful to you.
Regards, Stefan.
