I didn’t make any changes.
Netdrive is running, Dropbox and Google Drive drives are suddenly but not showing in FE and can’t disconnect in Netsuite display (error message “unmount failed” )
The local files listing is not updated, when I directly upload something to dropbox. Sometimes it works, after restarting my PC.
When I add something to the local dropbox netdrive directory, I either get a warning message that the file couldn’t be uploaded or no message and it’s still not uploaded .
Sometime I see all files and directories but then one directory is completely empty, even though there is content on dropbox.
It seems very temperamental and is very unreliable, which is critical because I keep loosing information this way, which makes netdrive unusable.
update:
I just added a new folder in my netdrive dropbox directory through file explorer, after I rebooted the PC. After the reboot, all looked fine, all directories were synced. The folder creation did not get executed and after that I got the message that new files added to existing folders could not be uploaded to dropbox.
