Is cloudsync support google team drive to another cloud drive ?
Sure. If you have a permission to use team drive, you can sync to another cloud service.
Thanks!
Thanks…
but i have one question and thinking to order 1 year plan…
how about if A cloud updated the files…will it update (transfer) to B cloud ?
CloudSync detects file changes(file size or file date) then CloudSync will update to target cloud service.
So is it mean if remove files / folder on souce , it will update on target?
No. Currently CloudSync does not delete file/folders on target. It will only create/update after changes on source.
Ok will you fix this issue soon ? Because it will be nice if doing as mirroring
