hello, the ftp connection with netdrive 3 is extremely slow and crashed the PC. It worked well with netdrive 2. Do you have a solution? If not, is it possible to downgrade our netdrive 3 license to netdrive 2 license?
same issue and questioon.
Sorry we missed this topic. Can you send us debug log file to check the issue?
log file attached.
Thank you.nd3svc.log (18.0 KB)
nd3api_firefox.exe.log (393 Bytes)
nd3api_NetDrive.exe.log (393 Bytes)
ndagent.log (10.7 KB)
nd3api_explorer.exe.log (369.9 KB)
nd3api_ndagent.exe.log (864 Bytes)
NetDrive3_gardon.log (7.2 KB)
nd3svc_FTP.log (146.5 KB)
According to your log, there are too many time-outs.
I guess your FTP server does not open ports for PASV or EPSV. You should open specific port or try active mode on your drive configuration.
